01-02-2016 08:29 - last edited on 07-20-2021 07:10 by JuanJoFitbit
When I go to synch with my phone it does synch and update my data, but there is a red exclamation mark on the right of the screen, it says couldn't reach fitbit.com to synch, any suggestions?
01-03-2016 09:49
01-03-2016 09:49
@Myrtlewalker Welcome to the Fitbit Community! Make sure you have Bluetooth and internet connection enabled on your phone. So, is it syncing even though that exclamation mark appears? Try to log out from the app and log back in. Also, reboot your phone and turn Bluetooth off for 10 seconds and then turn it back on. It should be working fine after doing all of this.
Keep me posted!
12-05-2016 15:57
12-05-2016 15:57
I have done all that and I am still getting the red exclamation mark, when I try to sync my fitbit. What else do I do?
12-07-2016 12:22
12-07-2016 12:22
@Boots55 Welcome to the Fitbit Community! Please do the same process once again but in this order:
Try that out and let me know how it goes!
12-07-2016 17:35
12-07-2016 17:35
You need to get used to it because that is going to happen 60-70 % of the time. You will have to log out log in; turn your phone off & then on; turn bluetooth off & then on. . . . . . too bad you don't log any steps; stairs; minutes doing all this because it takes quite a while, especially when you figure it is at least daily. Good luck & welcome to the world of FitBit.
Have a great day 🙂
09-22-2017 09:55
09-22-2017 09:55
I don't know if you ever fixed your problem but I wanted to leave this for anyone else who comes upon this page for help. Being around other devices with bluetooth on could be interfering. Try switching off the bluetooth setting on other near by devices or move further away from them so your fitbit is connecting to the correct phone/laptop/etc. This is how I fixed my problem. I recently switched my phone to a new one and my old phone still had the bluetooth turned on by accident so my fitbit was trying to connect to my old phone. I hope this helps someone (:
09-22-2017 17:50
09-22-2017 17:50
A warm welcome to the Community @NatashaA! Thank you so much for sharing with us what helped you getting a fix for this issue.
Hope I can continue seeing you around, you may want to check the Discussions Board and get healthy tips, sleep better or get moving.
12-28-2017 05:17
12-28-2017 05:17
Just a guess from my experience. I had to disable the Bluetooth connection to the fitbit on my desk top before I could update the fitbit on my smart phone without seeing the red circle with the exclamation point. I think the symbol was telling me that the fitbit was already connected to another device.
12-28-2017 05:30
12-28-2017 05:30
@Tom-D Welcome to the Fitbit Community! Thanks for sharing your experience with us! I'm sure that will be helpful for other users to try as it helped you!
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
Thank you again for sharing your experience. See you around!
12-28-2017 06:40 - edited 12-28-2017 06:41
Usually the red exclamation mark means that, for whatever reason, the tracker can't be synced at that time. For me, I usually have to force sync it a couple times to get it to go away, but you could try:
2.) Turning your Bluetooth on and off
3.) Repairing the Flex with your phone
4.) Syncing via Data instead of WiFi
5.) Setting it up as a new device
6.) Logging out then back in
7.) Uninstalling and reinstalling the app
8.) Doing a complete shutdown of your phone
9.) Performing a restart on your phone
10.) Waiting until later to sync your device. Sometimes the servers are busy, so syncing at an off-time should help.
Please make sure that when you try to sync all other Bluetooth devices that are nearby are either removed from the area or turned off, as this could interfere with the device's signal to sync.
Hope this helps!
one cruise ship at a time!12-28-2017 09:56
12-28-2017 09:56
I also have the red exclamation mark and sometimes says I have to disconnect other things that are using the Fitbit database(whatever that means as I have no other dongles or Fitbits trying to sync). I have no Bluetooth items, just my Flex and my laptop with its dongle for Fitbit. I am connected to Weight Watchers also (daughter did that for me so don't know how/what/ etc) The Flex was bought via WW. It does sync but takes a couple of goes sometimes. I have to take the dongle out then replace and try again and it works fine. So why do I get the red exclamation mark? xx
01-08-2018 06:54
01-08-2018 06:54
Thanks. This fix worked for me.
05-27-2018 12:40
05-27-2018 12:40
Thanks for that Natasha. I had an old phone still running in the same room.
Turning it off has fixed my red exclamation mark instantly.
Much appreciated.
06-07-2019 04:52
06-07-2019 04:52
This is exactly what was happening with mine. Thank you. After reading this I paid attention, and that red exclamation mark came after driving with bluetooth on. Good to know
07-20-2019 12:50 - last edited on 07-20-2021 07:10 by JuanJoFitbit
I don't have an answer but I am having the same problem with FLEX, the error message I get is "Windows cannot connect to your tracker. Please try rebooting your device. Check if your tracker is already connected to another device and disconnect them." Now my next question is how do you reboot the FLEX?
I read your message about the red exclamation mark and did a reboot. The reboot worked and now I'm recharging the FitBit and have NO red exclamation mark....there is a video on YouTube showing the reboot technique. https://www.youtube.com/watch?v=s9dX43gRKIo
Moderator edit: merged reply
09-26-2019 14:41
09-26-2019 14:41
Thank you!!! That was my problem!!
03-09-2020 04:13 - last edited on 07-20-2021 07:12 by JuanJoFitbit
My fitbit Charge HR won't sync with my phone or computer. It does have the red exclamation mark. I've done everything the instructions say to do. Nothing works.
I just tried what one of you said about turning my phone completely off and back on and it worked!!! I had just been restarting it. But shutting it completely down is what did the trick! Thank you!
05-20-2020 13:40
05-20-2020 13:40
12-29-2020 12:10
12-29-2020 12:10
I'm getting the same issues regularly with my Sense (like 4 times a week).
Usually it gets resolved by rebooting either the Sense, or the phone.
When it is not enough you can try switching off all nearby Bluetooth devices as well. As I live in a city, I get neighbors devices as well, so I have to make sure they also shut their devices. They didn't believe me at first ^_^, so I had to explain that I was having a Fitbit device and it was an issue they were having since 2016. They told me they'll make sure to avoid buying those 😄 Good laugh between neighbors! Thanks
07-12-2021 09:41
07-12-2021 09:41
Thank you! This finally solved my connection issue!
