You can enter it as either, whichever you would find more helpful. But you could also create a “custom activity” and enter it as cubii Jr - and then you would have a precise record to distinguish between other activities. If you never otherwise use an elliptical it might not be an issue, but you might want to distinguish your Cubii workouts from walks.
It takes an extra few minutes to set up a custom activity, because it must be done on the web based dashboard and not the app, but once set up on the web the activity will be available to you in the app.
To set up a custom activity go to the web based dashboard - there’s a link at the top right of every page when you are logged in here in the Community. Click on “dashboard”. From dashboard click on “log” and then “activity”. On the activity page scroll all the way down to the bottom and there you will see the option to create a custom activity. Type the name of the activity in the box (Cubii Jr in your case) . Once you have created this activity you will find it in your app in order to log the exercise. Just go to the log area as usual (on the exercise page click on the stopwatch top right and choose log). Start typing Cub... in the search box, and voila! it will appear as a logable activity.
I hope this helps!
