06-16-2022 06:08
06-16-2022 06:08
I have used excercise function in walk and bike mode. Time, avg bpm calories and zone minutes are noted. How do I get distanceto display?
Best Answer06-16-2022 10:05
06-16-2022 10:05
Hi @cymills. Are you doing outdoor walking and biking or are you using an indoor treadmill and spin bike?
Best Answer06-16-2022 10:47
06-16-2022 10:47
Thank you for responding, Heather. I am walking and biking, outside. Do you know how I can get the distance to show?
Best Answer06-17-2022 12:06
06-17-2022 12:06
I think it will show you the distance. On the app, go to your Account, then to Customize Display. From there you can select Distance. Good luck!
06-17-2022 13:40
06-17-2022 13:40
Thank you. Unfortunately, I could not see the customize display option. I utilized the live chat option. A suggestion was provided. Hopefully it will work. I will not know until I go out on my bike again...perhaps tomorrow. Thanks again.
Best Answer06-17-2022 13:42
06-17-2022 13:42
My pleasure Cymils🌹
Best Answer07-24-2022 10:02
07-24-2022 10:02
I am walking and biking outdoors.
Best Answer07-25-2022 03:26
07-25-2022 03:26
@cymills What Fitbit device are you using?
Best Answer08-08-2022 12:24
08-08-2022 12:24
I don’t know if you found this, but you have to press exercise on your watch then press bike or jog whatever you are doing. The gps tracks you then and you get a map with distance heart rate fastest slowest.
Best Answer08-17-2022 04:28
08-17-2022 04:28
@cymills If you rely on “SmartTrack” which automatically detects and records your activities you will not get distance as a statistic. That is how Fitbit chose to design the tracking.
If you would like to have your distance recorded you must manually start and stop your exercise using the app on your Fitbit device, as @Jaglenn says.
I hope this helps!
