What Fitbit device(s) do you have? I've got a Fitbit One (tracker), which has a rechargeable/non-replaceable battery (no problem so far) and a Fitbit Aria (scale), which uses regular AA batteries (4 of them). I'm still on my first set of AA batteries with the Aria after 13 months. If you're using a tracker with replaceable batteries (Zip?), you may want to consider using rechargeable batteries. Alternatively, you could upgrade your tracker to a model with built-in rechargeable batteries (One, Flex).
Dominique | Finland
