08-01-2014 06:23 - edited 08-06-2014 01:44
I think the Fitbit step goal thing is not as good as it could be. I found myself wishing for a system that looks at your average step count over the last 2 weeks and calculates a goal for you that's slightly higher than your average.
Then I made this spreadsheet, which you can view and copy and use yourself.
You do have to update it with yesterday's steps each day, but at least the step goal changes to reflect what you've been able to manage recently, with a box where you can add a little extra for the challenge. 2% is a good daily increase, I find.
Edit: Updating the screenshot because it has more features now, like the ability to change what % you're increasing your goal by (including to 0%), and colourful boxes to show at-a-glance improvement trends.
Edit: It might help if I put in a link to the actual spreadsheet. 😉
08-01-2014 06:38
08-01-2014 06:38
That is awesome! I'll have to try it out sometime. Thanks for sharing. 🙂
Best Answer08-01-2014 07:13
08-01-2014 07:13
Best Answer08-01-2014 10:58
08-01-2014 10:58
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Best Answer08-01-2014 13:19
08-01-2014 13:19
Best Answer08-06-2014 01:44
08-06-2014 01:44
I'm just bumping this because it has many fancy new features now!
Best Answer02-01-2022 13:00
02-01-2022 13:00
Did you automate this in any way? I am looking for a simple way to challenge my colleagues in a step count challenge.
Best Answer02-03-2022 01:35
02-03-2022 01:35
I have premium and when I set All For One challenges, it does just that. It looks at your average for x period and slightly raises it. So the coding is in the app, but if this was on the dashboard for a daily goal, it would be perfect. I know the Garmin? does just that. My Auntie gets new daily goals depending on how well she is doing.
it would be really beneficial for those who get into a slump and need a little motivation that isn't so scary.
