08-07-2014 03:14
08-07-2014 03:14
if one participates in strenuous activities (in this case Tae Kwon Do and surfing) how can one get the Flex to recognize those as "very active minutes"?
no doubt that TKD for 50-60mins is strenuous and likely burns 400-500 calories. same with surfing (usually lots of 'spirited' paddling), which is usually two hours or so.
currently, i estmate the calories burned and enter that when i log the activity. one can eiither log 'miles' or 'calories' with an activity, but it doesn't seem there is always a correlation between what i've logged (eg 50 mins of intense TKD= 475 cals burned) and the total of 'very active mins". thanks for any advice.
Best Answer04-21-2016 16:01
04-21-2016 16:01
@Heybales wrote:
And your can indeed tweak the height on Fitbit so it's formula ends up
at the same BMR if a big difference.
Must adjust stride length manually though since it's calculated from height
and gender.
I run with a Fitbit Surge in GPS mode so I don't fuss with the stride length; makes my life easy. Why? A couple of years ago in my pre-Fitbit era, my company was issuing waistband pedometers and, at the time, I would run almost exactly 16,000 steps for my normal 10-mile/16-kilometer trail run; roughly one meter per stride. If I bumped the pace up, the step count dropped and vice-versa. Now with the Surge I don't need to mess around figuring out my stride length (easy for a 10-miler, less so for something like 8.45 miles), I just look at the results of the run (distance and steps) which shows me my stride length changes in a fairly dynamic manner.
Case in point, this Tuesday I did a 12.45-mile/19.92-kilometer trail run in 19,903 steps, meaning 1,598.636 steps per mile (or one meter per stride; pretty much in line with a couple of years ago); that said, during my most recent 5K race I logged only 3,725 steps meaning 1,201.613 steps per mile (or 1.342 meters per stride).
Trying to figure out what my stride length was going to be on any give day would drive me bonkers. 😛
Best Answer04-21-2016 18:26
04-21-2016 18:26
@shipo wrote:The calculator link provided in the above post from @Colinm39 is interesting, however, I think it is flawed. Why? Said calculator only uses weight, height, age, and gender as it's metrics; while I've never used a calculator like this before, I cannot wrap my brain around a calculator which indicates the same BMR for say, an obese 250 pound individual of any given height, age, and gender versus a heavily muscled 250 pound individual of the same height, age, and gender.
@shipoI agree with you totally and that is all Fitbit uses with their calculations. Even with variations between how you enter the data. So it's all trending graphs for me, and you can't beat the scales and a tape measure and RHR
I just tested a manual activity for walking at 2 mph and entered it two different ways.
I didn't compare the Walking table because of the unknowns. For instance 50 years ago my BMR would have been another 255 calories higher based on the Mifflin equations. (5 calories per year)
The first was the 2 miles distance walked in 1 hour, the 2nd was 2 mph for an hour.
Results 168 calories and 134 calories respectively.
It gets worse, 4 miles distance walked in 1 hour, the 2nd was 4 mph for an hour.
Results 328 calories and 132 calories respectively
I reported these variations to Fitbit a couple of years ago,and fortunately I don't use manual activities, and if I did, it would only be for the non tracker detectable activities.
Best Answer04-21-2016 22:13
04-21-2016 22:13
04-22-2016 13:29
04-22-2016 13:29
Best Answer04-22-2016 14:14
04-22-2016 14:14
@Dollydenim Good to see you back. There is nothing to setup. Have you got the Active Minutes image in the cluster of goals with your steps?
@Dollydenim wrote:
I wanted to know how to set up the active minutes on my fitbit profile to use it, unless the activities I'm doing aren't long enough or aren't the same long enough for the fitbit to count it
Best Answer04-22-2016 14:49
04-22-2016 14:49
@Dollydenim Walking at least 2.5mph (4 kmh) for 10 continous minutes could give you a bare minimum of active minutes. If you want to examine the type of activities that you can try to get your active minutes recording use this link which Fitbit use for the categories of exercise. Rather than get too complicated, it uses a measure of METs and you are looking for any activity with 3 METs or greater.
Best Answer04-26-2016 12:34
04-26-2016 12:34
With Fitbit's active minutes it can go either way. It is about the duration (I think it needs to be at least 10 minutes in duration, is that still true?) and it is about the calorie burn per minute. The calorie burn needs to be a certain ration more than your resting calorie burn. I believe it is what is considered moderate activity on up. Oh, and it also needs to be activity your tracker can sense unless you are manually logging (this will vary a little depending on the type of Fitbit you have so it makes it a little complicated).
As far as settings go, the best thing is to make sure your stats are accurate and possibly to make sure your stride length setting is reasonably accurate. I set mine for a normal fairly brisk walk and my running stride is jogging with a shorter stride. Also, if you are doing activities that your Fitbit doesn't track well, for example you have a One and go to spin class or lift weights. Or you swim but use well, any fitbit (sonce they are not waterproof or programmed to track swimming). Then manually logging your workout will make your active minutes more accurate for your true activity level.
I hope that makes sense, it is hard to give a dumbed down but meaningful answer.
I objected to the change to a minimum duration because I sometimes do interval activities where I work vigorously for 1-2 minutes then recover. I don't get as many active minutes from these as before this change but my heart rate monitoring fitbit does okay with this. If I were only using my One, I would need to log the interval workout.
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Best Answer11-27-2016 09:50
11-27-2016 09:50
