02-19-2014 18:53
02-19-2014 18:53
I am using the Fit Bit to try to keep track of activity but I don't think the active minutes calculates correctly. I take one or two arobics classes a day and the most active minutes I have recorded is 8 minutes. Any suggestions??
Best Answer02-19-2014 20:02
02-19-2014 20:02
i didn't think it was working right either. but you actually have to log the activity you did and for how long. so you need to click on to the activity minutes. in the upper right hand corner you will see a plus sign. click on that. go into the search mode type what you did and you should see what you are looking for. you might have to put in the minutes you did
hope this helps 🙂
Best Answer02-20-2014 05:26
02-20-2014 05:26
I agree that you have to add the activity manually.
Here are three real life examples from my history. One -- shoveling snow. The steps alone didn't account for active minutes, but manually entering shoveling snow as an activity sure did. Two -- treadmill at an incline. My walking pace isn't fast enough, but the treadmill at a 5% incline is. The third is the funniest. I once used the Activity Record while using a recumbent elliptical. Because no steps were recorded, my Fit Bit thought it was a sleep record. I manually recorded the activity and calories from the workout summary and voilà.
There are a couple of "aerobic" choices from the activity list that you can choose from. I think it will help you a lot.
Fit Bit counts steps. Sometimes it needs help.
Laurie | Maryland
Best Answer02-20-2014 06:17
02-20-2014 06:17
I wouldn't think you'd have to manually log aerobics.
Best Answer02-20-2014 07:34
02-20-2014 07:34
Fit Bit is great with steps. Effort based steps, not so much. As another example, I just took a segment of time where I was doing laundry. When I made an activity log of that time to light intensity aerobics (same number of steps), the calorie count went up to the moderate -- yellow range. When I edited to to be high impact aerobics, it went to the very active -- green range. Same number of steps.
The newer numbers looked nice, but I re-edited it back to the recorded steps.
Laurie | Maryland
Best Answer02-20-2014 10:21
02-20-2014 10:21
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Best Answer02-20-2014 10:28
02-20-2014 10:28
Sam | USA
Best Answer02-20-2014 13:51
02-20-2014 13:51
Best Answer02-21-2014 02:33
02-21-2014 02:33
I have a One. I wear it on my bra, in the little pocket on my workout pants, or on a belt loop.
In my elliptical example, it is a recumbent (sitting) elliptical. It couldn't sense any movement. Next time I will try it on my foot.
I also heard others say that the wrist worn fitbits don't count all the steps when holding the treadmill rail.
I manually enter the activities that the Fitbit underreports -- like the snow shoveling. And I use the computer dashboard. I do look at the app, just haven't used it for recording activity.
Laurie | Maryland
Best Answer02-21-2014 08:20
02-21-2014 08:20
Putting a One on your foot is going to over-estimate your calorie burn by 2-3x, in my experience. A One assumes it's on your torso, detecting walking/running motion on a body that is upright and unaided and unhindered.
