05-19-2017 10:02
05-19-2017 10:02
I walked 5.4 miles almost every day and it still say's NO ACTIVE minutes....What the hell Fitbit??~!!!
05-19-2017 10:10
05-19-2017 10:10
Check what times ur active minutes are set between. You may be walking at times outside the settings. My active minutes are set between 1pm and midnight cause that's when I'm most active
05-19-2017 10:10
05-19-2017 10:10
05-19-2017 10:14
05-19-2017 10:14
@EmjayH wrote:Check what times ur active minutes are set between. You may be walking at times outside the settings. My active minutes are set between 1pm and midnight cause that's when I'm most active
That doesn't make any sense. It's supposed to record the minutes that you are *actually* active.
05-19-2017 10:19
05-19-2017 10:19
05-19-2017 10:29
05-19-2017 10:29
They only register i think if you are active for more than the default 10 minutes or whatever you have the setting at in the app.
You can go in and change it.
It means you have to walk for more than 10 minutes at a time before it starts seeing it as 'active'.
05-19-2017 10:31
05-19-2017 10:31
06-29-2017 11:07
06-29-2017 11:07
How do you set your active minute times? I have my 250 an hour step time set from 8am to 8pm. But that does not record my active minutes. I ride my stationary bike for 20 plus minutes and I walk for at least 10 minutes in the mornings (after 8am) but it only records as a work out not active minutes. So I am confused.
06-29-2017 12:16
06-29-2017 12:16
https://help.fitbit.com/articles/en_US/Help_article/1379
Either your tracker isn't picking up all the steps or what you are doing is not strenuous to count as active minutes.
