12-14-2017 20:10
12-14-2017 20:10
I don't have the Ionic yet but I am wondering if their is a basketball exercise mod on the Ionic. And do you play basketball wearing the Ionic. I don't know if I should risk getting it slapped and breaking so...
Best Answer12-20-2017 17:12
12-20-2017 17:12
it is not, but following @Mukluk4 advice should work for you. I have the ionic and it is bigger than the charge 2 in width, so when you are deciding what to get to cover it, make sure you have it with you..
Elena | Pennsylvania
Best Answer12-15-2017 07:01
12-15-2017 07:01
I wear a Charge2, let it auto detect the Workout and then change the description to basketball.
I also wear a sweatband over it more to protect other people than the watch itself.
12-20-2017 17:12
Best Answer12-28-2017 07:54
12-28-2017 07:54
thanks so much
