It is winter and my outdoor bike is on a trainer. I am doing HIIT using Spinerval Cycling DVDs for 45-50 minutes. Yet, Versa only shows I burn 250 calories.
I am using the Spinning feature on the Versa since the Bike feature only seems to work outdoors with GPS.
Can anyway tell me why the calories burned are not registering more?
Thanks,
MTGatorGirl
Best AnswerThanks, Bill. It just seems it should be a little more given high intensity intervals.
