to take it off of todays calories, put your cursor over the food you want to delete and an x will show up to the left, just click the x. Then go up to your date and go to yesturday and add it there. Hope this helps.
Best AnswerComputer web browser view, or app view?
Either way, just change the day you are viewing.
Corrections will sync over to Fitbit.
Best to ask your question on the site (MFP) where you are having the actual question.
Because guess how many on the MFP site use MFP.
Now guess how many on Fitbit may use MFP.
