11-05-2020 08:50 - edited 11-05-2020 08:52
Apologies if this is posted in the wrong place but i'm a longterm fit bit user currently using an Ionic as well as a Surge but i have recently been bought a very nice anologue/old fashioned watch as a gift. Does anyone know of a wrist fitness strap or Band without a watch that records HR & steps than can be worn on non-watch wrist rather than having to wear 2 watches. Thanks in advance
Best Answer11-05-2020 10:45
11-05-2020 10:45
Hi @ahollamby all Fitbit products have the time on them. Might you wear your gifted watch on your usual hand and the Fitbit on the other?
11-05-2020 16:22
11-05-2020 16:22
@ahollamby -- I know what you mean, you've only got two wrists and it kind of looks weird to wear a watch on each one. (Though I'm used to doing it now and no-one shames me anymore). Anyway, the Charge 4 is more of a strap-type fitbit that you could wear on one wrist while wearing your classic watch on the other. The Inspire 2 is a less expensive strap-type fitbit. Both tend to look less weird that having a second watch sized tracker on the arm opposite of your classic watch. I like the CH4 better, though, because it counts floors and that is a favorite metric for me.
Scott | Baltimore MD
Best Answer11-09-2020 15:23
11-09-2020 15:23
most of the ones that don't look "watchy" don't do HR. I do like the inspire suggestion as the tracker is pretty slim and if you get it all in black, it wouldn't stand out. I will say when I first became a fitbit wearer, I couldn't give up my watch, so I wore both on the same wrist. only a few people made jokes about it- most don't care. I did eventually give it up..
Elena | Pennsylvania
