04-11-2024 05:18
04-16-2024 07:02
04-16-2024 07:02
I use the Walk app on my Fitbit Inspire 3. I track it with GPS. When I check it on the Fitbit App, it shows my pace in min/mile for each 0.5 mile "lap" at the bottom of the screen,
04-22-2024 03:44 - edited 04-22-2024 03:58
@s1anda yes. The splits breakdown is missing. Well, Fitbit fixed one thing (duration has seconds now) and another one 🤷
Best Answer04-22-2024 10:33
04-22-2024 10:33
@s1anda in the trackers Run settings turn on laps (it may be different option, depends on device you own). This is annoying. I also remember it used to work without custom lap setting (then it was either by km or mile). I want to see breakdown but don't want to be buzzed with each lap 🤷 There is no other option on my Charge 6.
Best Answer04-22-2024 22:58
04-22-2024 22:58
Hi @Triletics ,
I can see my lap breakdown just below where you indicate on your screen shot. I'm on Android and my last run was last week and it definitely shows the per KM lap breakdown.
BTW, how do you include a screenshot in your posts please? I get told it's not allowed. Maybe the pic is too big 🤔
Anyway, hope you find the data you require!
Best Answer04-22-2024 23:15
04-22-2024 23:15
@Goldsgirl your screenshot has a dash symbol in name. You need to rename it to paste it. Weird limitation of forum.
Best Answer04-23-2024 02:42
04-23-2024 02:42
