02-27-2014 17:22
02-27-2014 17:22
I generally wear my Flex bracelet on my left hand (non dominant) side. Yesterday I switched sides and wore it on my right side and find I achieved the 10,000 steps sooner than I normally do.
I did the same type of acivity. Does it make a difference which side you wear the bracelet?
Best Answer02-27-2014 19:07 - edited 02-27-2014 19:08
You need to make sure you change the settings from Dominate or not. Its under settings
Wendy | CA | Moto G6 Android
