Hi,
Its my first post in the forum.
I used to play "Badminton" on all possible morning. What Exercise mode do I need to set? And one more, While I ride bike, the fitbit surge correctly identifies it, is it possible to log the path with GPS?
I use MapMyWalk, MapMyRide, MapMyRun apps on my phone to track with GPS and that syncs to the FitBit HR. Great combination.
Best AnswerHi, I noticed last week when I played badminton that my surge had automatically tracked it as exercise, as it has an auto feature if notices you exercise for >15 minutes. Another option would be to go into the Exercise section and select Workout.
On my Surge the Bike option under Exercise shows a satellite transmitting icon in the lower left hand of the screen which indicates that GPS will be used to track your journey.
Hope that helps
Best AnswerHello Responders,
Nice to see #Fitbit gave an update for #Bikers, after posting this thread.
https://blog.fitbit.com/bike-tracking-now-available-on-fitbit-surge/
I'll be using this features, for all my future rides.
If #FitBitDev team helps us to create our own custom exercise, it can go even go golbal.
