01-12-2015 17:46
01-12-2015 17:46
06-16-2015 09:49
06-16-2015 09:49
And when I look at my phone exercise history, they are all doubled. This doesn't double the steps but they are all listed twice, which is wrong.
Best Answer06-16-2015 11:08
06-16-2015 11:08
No, you are reading that incorrectly most likely.
Look at the 2 entries, are they actually exactly the same?
Activity record is stats from the device when you pushed the button.
Workout record is from using the GPS function in app, it replaces the stats that Fitbit provided for steps, distance, and calorie, with it's more accurate info.
Look at my profile, Activity page. I purposely have actvity record prior to manual logging of workout.
Then the workout record too.
Best Answer06-16-2015 11:10
06-16-2015 11:10
@scudmore1214 wrote:I just went for a quick walk at work and set the exerice tracker on my phone. Apparently the GPS or something wasn't working, so there was no activity recorded. When I went into the dashboard and logged the activity it doubled my steps and distance. What am I supposed to do to keep activites working for an accurate look back on my exercise?
so you saw the stats for the day increase by a huge jump right after you manually logged the workout?
Don't need the GPS, step accuracy probably close enough.
Best Answer06-16-2015 11:27
06-16-2015 11:27
This is what my phone shows. Also, concerning the other issue, I will just use the activity button on the fitbit and not my phone but it should work.
Best Answer06-16-2015 17:30
06-16-2015 17:30
Your image was too small for me to see the actual words or details (I enlarged it but the resolution was too low to read). But something does look funny to me. What are all those GPS maps? On my Surge, I only get one map per tracked walk when I use the exercise mode on the watch. But, I never use the tracking mode on the Fitbit app. Often I use the activity/sleep mode on my Fitbit One but that does not make GPS maps. Where are your maps coming from? Are they from the Fitbit app? Or do you use a Surge? (if so, are you also using the app, if you are maybe stop using the app to track), or do you have another service like Endomondo, Strava, etc that you set up to sync to Fitbit?
If you are synching from multiple sources you can end up logging more than once. I often see two records as HeyBales described but that is when I use the timer on my Fitbit One (this applies to others, but maybe not the Surge) and then manually log an activity or use a third party app that logs for me. In my case, one record shows what fitbit would have tracked (but no map since my One does not have GPS) and the other record shows what I overwrote the Fitbit data with. Sometimes people think this is counting both, but it is not (in my case nor should it be). Your picture looks like something different is going on, but I can't see the times on your listings. I don't use the tracker in the Fitbit app though as I really see no need for it in my case and when I tested it, I didn't like how it altered my step count.
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
06-16-2015 22:09
06-16-2015 22:09
Wow, good eyes. I see pretty blues and some other slight colors.
06-17-2015 05:59
06-17-2015 05:59
Best Answer06-17-2015 06:01
06-17-2015 06:01
I use a Fitbit Charge w HR and I do not track using anything else. So, not sure what the actual issue is, but again, thanks for your help
Best Answer06-18-2015 03:01
06-18-2015 03:01
06-18-2015 03:05
06-18-2015 03:05
Best Answer06-18-2015 04:45
06-18-2015 04:45
Thank you all. I don't see my activities twice on my phone anymore. Must have been a bug.
The issue of doubling steps was bit different. I would try and use my GPS tracking on the phone and when it wouldn't work, I would log the activity manually. This is when it would double my steps. I just won't do that anymore.
08-10-2015 07:21
08-10-2015 07:21
I record walked steps on Fitbit. If the battery runs low, though, I remove the Fitbit and wind up not recording steps during that time. I have entered these through the Activities module but these steps are not averaged in with the regular steps. Is there a way of including these in the dashboard steps graph?
Best Answer08-10-2015 07:33
08-10-2015 07:33
