I'm seriously considering getting the Fitbit Premium. Appreantly, at some point I started the free trial although I don't remember using it.
My question is, are all of the extra features available on the app? Or only on a desktop PC? I rarely use my desktop anymore, and don't know if I would utilize the premium features if they weren't available on the app as well.
I'm not really an expert on Premium, but as far as I know, the Fitbit.com Dashboard is the only place to review your Premium Reports. That said, it's a once-a-week process to go in and review and/or print whatever you want, and if you set up a Trainer plan it impacts the mobile app calorie information as well as the Dashboard.
If you can manage to get to the Fitbit.com Dashboard once a week or so, I find the information quite worthwhile.
Hope this helps!
Charge HR, Flex | Windows 10 | Android | iPad
Hope this helps!
