07-04-2021 04:08
07-04-2021 04:08
I just got a fit bit charge and the heart monitor is constantly reading my resting bpm to be in the 50s, mostly the high 50s. I know this isn't going to be exact and the only reason that I'm worried is because when working out, omegle xender I have had to stop because I felt like I was going to pass out or I knew that if I even kept standing I was going to blackout. I do have iron deficiency anemia which has causes me to pass out before but that was years ago. So I'm not sure whether I should be concerned about the low ratings and if it is something I should be checking in with a doctor about. Any advice?
thankyou my issue has been solved
07-28-2021 09:46
07-28-2021 09:46
A resting heart rate in 50s isn't something to be concerned about as a single data point. In fact if you are active, sleep enough and eat well, you likely have a resting heart rate in the 50s. However, if you are feeling light headed or blacking out, you should contact your doctor for advice. It could be a number of different things causing the issue and best to talk to a medical professional.
