12-17-2015 16:42
12-17-2015 16:42
I'm a skinny fat body type should I be going for a flat stomach or abs (unless that will help me the same idk)
I use 2 videos
https://www.youtube.com/watch?v=LebPal5gKrc
https://www.youtube.com/watch?v=HrpW5PliIdU
Which one should I do first or do both of them?
Best Answer12-20-2015 10:53
12-20-2015 10:53
Try a plan such as the 7 move video 3 days a week (Mon, Wed, Fri) for a few weeks or a month. Then step it up to the 9 move video in a similar format.
Best Answer12-24-2015 21:44
12-24-2015 21:44
Alright, here's the dealio on the skinny-fat body type with regard to abs.
Basically, you've got a high percentage of bodyfat even though your overall weight is low. That means you've got a lot of fat, and not a lot of muscle.
SO, what that means is that you've got a nice layer cake of fat over your belly. (Most likely, I'm not actually looking at your belly). Having a flat belly and having "a six pack" are basically the same thing. The only difference is that a flat belly means you've got a really thin layer of fat over your abs, and a six pack means you have no fat over them.
Getting to my point-- the only way to decrease the amount of fat over your abdominal area is to lose fat everywhere. There is no such thing as spot reducing. Now, keep in mind I didn't say "lose weight" I said "lose fat." So, theoretically, you could decrease your amount of bodyfat by working out in general, and also gain muscle in the process. This would either increase or maintain your weight. You would have to figure out approximately how many calories you burn in a day. (Try this link: http://tdeecalculator.net/) then eat that many calories or more if you don't want to lose weight.
Tl;dr Either of those videos are going to work your abs but you're still not going to have a flat stomach if that's the only thing you do all day.
