How to log an activity, but keep my active minutes?
ANSWERED
Hi everyone,
I've had my fitbit for quite a while now, but I only recently started excercising regularly.
This morning I followed a yoga class, which gave me about 40 active minutes and 216 burned calories. Yoga isn't automatically logged by fitbit, so I manually added it. However, it says now that the activity has 0 active minutes, which reduced my total active minutes. Also the 216 burned calories I filled in while logging are now on top of the 216 burned calories fitbit registered, so it's doubled. When I fill in 0 burned calories, it makes my total 0.
I don't know how to get it right, so I hope someone has te answer for this. Please let me know!
1 BEST ANSWER
Accepted Solutions
I like @Colinm39‘s approach. When I go to the gym I generally start a ‘workout’ or ‘weights’ from my the shortcuts on my Fitbit and just leave it after that, no matter what I actually wind up doing.  (Starting an activity will cause your Fitbit to sample your heart rate more often).  Changing labels after the fact when you do something different helps you keep things straight though ...
Scott | Baltimore MD
7 REPLIES 7
@SunsetRunnerYoga is an option in my Fitbit exercise short cuts. I also use Workout and rename that.
I avoid using manual entered data because it can average out your effort because you need 3 times your BMR for at least 10 continuous minutes to accumulate active minutes. Many over the years have complained of the same issue.
I would delete that manual record, learn from it and progress using the features in your Fitbit..
Colin:Victoria, Australia
agreed. If you think your fitbit won't auto detect an activity, start one before you begin exercising. If you forget, just let it go...
Elena | Pennsylvania
Thanks so much for the explanation. I might be a total noob here, but I can’t figure out how to start registering an activity when my fitbit doesn’t automatically.
@SunsetRunner What model Fitbit are you using?
@Colinm39 I have an Alta HR.
@SunsetRunner  I can see your issue.. Here is the Altra HR manual  is the manual
On Page 21 it mentions Smartrack
Track your exercise
The SmartTrack feature automatically detects selected exercises and records the details in your exercise history. By default, SmartTrack detects continuous movement at least 15 minutes in length.You can increase or decrease the minimum duration or disable SmartTrack for one or more exercise types. For more information about customizing and using SmartTrack, see help.fitbit.com
Based on the 15 minutes continuous maybe it's not enough activity level to pick up the activity.
What I would be doing is manually log your activity via the PC Internet and use the activity record image.jpg
in your Activity Log. Give it a name for the activity and you may have to create it in Custom. This is a non destructive way of seeing what your activity was and it gives you graphs like this when you click on the small stop watch next to the Description. a start rather than outlay on a more modern device.
