How to track cycling
How do you track cycling?
3 REPLIES 3
Hi @Banker9  The easiest way is to just get on your bike and ride. Your Tracker should auto recognise a bike activity. Or you can manually start and stop a bike activity in the exercise app (running man) on your Tracker.
Community Council Member
Helen | Western Australia
You can also use the trackers to monitor your speed and distance traveled
I track cycling with a Garmin because I like much more data than Fitbit can provide.
Then a manually created Workout Activity is created with calories and distance.
Help the next searcher of answers, mark a reply as Solved if it was, or a thumbs up if it was a good idea too.
