With the new year jsut around the corner, is there any way to export all the current data from ones Fitbit account and start over from scratch without deleting the account? I'd like a fresh start with the new year to see how long it takes me to reach the all the goals in 2016 as compared to 2015.
Thanks,
Jason
I think the easiest way to achieve this would be to create a new account (with a different email address) for 2016. You will then be able to choose which to logon to and view data. Your fitbit would only work on one account though so you'd need to set it up as a new device on the new account.
