I'm forced in my workplace to use my non-dominant hand a lot, and there's been some days where that leads to the app recording me as having walked 20k steps. Which would be better, switch the tracker to my less-used arm during work, or change the app setting during work to dominant?
Best AnswerHi & welcome @Postalwalker
If it was me, I'd switch the tracker to my less used arm during work. Since it's a physical change to switch between arms, I'd do a better job of remembering to switch it back to my non-dominant arm after my work shift than if I make the change in the app.
Hope you find a solution that works for you.
