12-21-2017 08:43
12-21-2017 08:43
Hello Fit Bit 'ers-
I used to be an 8-10K step a day person till I had my right knee replaced (TKR) last August. Getting back into it, but am still struggling to get more than 5-6K a day right now. Wondering the following:
A) are their people in this particular group who have experienced anything similar, and if so, can you share with me how you got back to a 10k+ day
B) Do you know of other groups on here that I might follow that deal with this particular issue, and motivation to get back on course?
Thanks in advance for any information or advice!
Joanne Y
Best Answer12-22-2017 04:58
12-22-2017 04:58
Hi Joanne, Your surgeon has probably already told you that it would be at least 6 months to a year before you are back up to your max capacity in terms of strength, decreased pain and swelling and activity level. It will be a steady and gradual process which varies from person to person. Be patient and you should be pleased with your results barring any complications or any other medical issues. Best of luck, stay in motion. Carolreb
Best Answer12-22-2017 08:42
12-22-2017 08:42
JoanneY: As a Physical Therapist with 38 years experience I had many clients that had a total knee. When asked similar questions concerning what were their limitations, this was before fitbit and step counts, my answer was always the same, Listen to your body! Never train through pain, so if you experience pain after 5-6K steps that is your limit now. Also measure the circumference of your knee before walking and then again after walking, if there is increased swelling you have done too much. Swelling inhibits all the muscles that that control your knee, so if the swelling increases you are defeating the purpose of increasing your step count. Also if you are still limping, your walking is not improving the muscle strength in that leg. Every person is different, every total knee is different, I have heard of no such rule that states it takes 6-12 months to get back to your original functional level since every case is different. Walk on the softest surface most even surface you can, avoid walking down hills, inclines and a lot of steps since this puts a lot of stress on the patellar/ femoral joint surface. Walking up hills , inclines or steps is much easier on the knee than going down. I would also ice your knee after walking, use a 2 pound package of frozen peas or corn and place it around your knee for 20 minutes, than put it back in the freezer to use again, also limit the use of NSAIDS( non-steroidal anti-inflammatory drugs) they reduce pain but also decrease inflammation which slows down healing since inflammation is the first stage of healing. Good luck and have a wonderful Holiday Season!
