I work two jobs(I work from 7:30AM to 11PM) and I have trouble getting to the Gym. I would like to know how to fit in my Workouts and if someone else has this problem.
Gee, I feel for you! Hopefully you will be able to switch to a more sustainable working schedule at some point, sooner rather than later. Until then, I think there are other higher priorities for you than finding time to work out at the gym. One would be sleep. Another one would be eating (including the time needed to shop for grocery and prepare meals. Both are hugely important for your health and well-being. I assume your current schedule and time constraints don’t allow you to get enough quality sleep and have optimal eating patterns.
Dominique | Finland
Dominique | Finland
I would go walking at Lunch time just to relive some stress
Wendy | CA | Moto G6 Android
Explore flex scheduling with one of your two employers and see if they're cool with, say expanding your lunch time to 2 or 2.5 hours in exchange for making up those hours remotely or at times they need someone but are typically light (I'm thinking retail on a weekday evening for example). I just swam through my lunch "hour" today (it was more like 1.5 with travel time). Another thought is consider 24 hour gyms if your circumstances allow it. When I was a bartender I worked out at 2am (which was brutal after standing for 9 hours) but the place was vacant and I made it leisurely. Hope that helps.
Best Answer@Sjanae90 That sounds exhausting! I would try fitting in some workouts during your lunch break if you can. Just walking on my lunch break helps reset me for the day. Best of luck!
