The help forum is a forum where you can post or answer questions.
You may need to change the sensitivity on your fitbit. If you use the setting for wearing on your dominant hand, it will reduce the sensitivity.
Am unsure how you are typing to get 15k steps though as I have just spent the last 4 hours typing away for an essay and didn't gain a single step!
@rudyten @TessCu exactly what Tess said..
You either need to change hands or sensitivity. I am on a computer all day everyday, and never get steps by typing. There are reported instances while driving, being on a motorcycle, clapping, vigorously shaking your arms and weight lifting. Typing is for sure a new one.
Elena | Pennsylvania
