09-05-2017 05:11
09-05-2017 05:11
I'm having problems recording more than one walk on the same day. Today I recorded two separate walks using the weekly exercise feature on my Fitbit but only one is showing on my exercise dashboard. Why is that?
09-05-2017 05:52 - edited 09-05-2017 06:10
Welcome to the community, @HensbyC! What Fitbit model are you using? I’m not aware of a weekly exercise feature on the actual tracker. My understanding is it’s a feature on the Dashboard of your mobile app. You record your activity (e.g. walking) on your tracker (if supported, which is the case for instance on the Charge 2, but not the Alta HR) and it will appear in the weekly exercise tile of your mobile app. The activity may also be autodetected, in which case it will also appear in the same place. In order to be included in the xx out of yy Days weekly exercise count, activities must exceed a certain threshold in duration.
As it happens, I had two walks this morning, and both showed up in my weekly exercise list:
One has distance and a map (because I formally recorded on my Surge), the other one was autodetected (forgot to record it), so it has no map/distance.
Dominique | Finland
09-05-2017 06:24
09-05-2017 06:24
@HensbyC wrote:I'm having problems recording more than one walk on the same day. Today I recorded two separate walks using the weekly exercise feature on my Fitbit but only one is showing on my exercise dashboard. Why is that?
Hmmm, never seen that issue; I routinely record more than one walk, or hike, or run on any given day and always see tracks/maps/stats for each.
09-05-2017 10:15
09-05-2017 10:15
Are you clicking on the tile so that you can see all your exercise activity? It should show on the laptop app automatically but the phone app doesn't have a big enough screen.
09-05-2017 11:24
09-05-2017 11:24
Hey, thanks for your reply. The walk isn't showing on the activity list on my computer. I've now added it manually, but another anomaly has cropped up. It was more or less the same walk in reverse, c1.4 miles v 1.47 miles, but Fitbit converted it to more steps (3,357 v 2,912) and less calories 73 v 150)! Don't understand why that should be.
Best Answer09-05-2017 11:36
09-05-2017 11:36
Hi Dominique
Thanks for your reply. I have a Fitbit Flex which has a weekly exercise tracking feature that allows me to record walks and runs. It rarely, if ever, auto-detects walks and I regularly walk up to 8 miles or more at a time without setting record (maybe the Flex doesn't have that feature). Today's walks were both 1.4 miles and I recorded both manually, although only one showed in my activities list on my computer dashboard. It's a bit of a puzzle and frustrating too.
Best Answer09-05-2017 11:39
09-05-2017 11:39
Hi Shippo
Seems like I may have a problem on my Flex.
Best Answer09-07-2017 05:39
09-07-2017 05:39
I'm not familiar with the fitbit flex, so I'm don't know why your walks aren't showing. Is it possible to start the exercise at the beginning and stop when done without using an automatic feature? As for the calories-they would be dependent on the exertion (heartrate).
Best Answer10-23-2023 13:24
10-23-2023 13:24
I have fitbit sense. The android fitbit app version is 4.2.1 (40243041). Last Saturday 10/21/2023 I went on 2 hikes. My activity on my web login dashboard shows the 2 hikes being recorded, but my fitbit app only shows the 2nd hike.
Previous versions of the fitbit app did show me all exercises in one day, eg. Tennis, biking and swi.ming in one day.
I have started the phone to no avail.
Thanks
Hung Bui
05-26-2024 05:59
05-26-2024 05:59
Same problem here. The app only shows the last activity of the day in the dashboard app on Android.
Please Fitbit, fix this bug.
05-29-2024 23:39
05-29-2024 23:39
It's by design. To see all you need to tap this:
07-10-2024 12:24
07-10-2024 12:24
THANK YOU!!! That worked 😅
Best Answer09-11-2024 14:45
09-11-2024 14:45
When I do more than one exercise in a day, they all show up when I click on the Exercise tile of the home screen.
