01-27-2014 02:03
01-27-2014 02:03
Does anybody else do the curves workout? or know what you would record as extra activity above the steps you do?
Best Answer01-27-2014 05:23
01-27-2014 05:23
I donn't do the curves workouts but i found a link for you that if you enter your weight and the amount of time spent doing a curves workout it will tell you how many calories you have burned.
Curve calories burned link: http://www.sparkpeople.com/resource/calories_burned.asp?exercise=151
If you repeat the workout I would just create a new activity and give it name that you will rmember "Curve workout 1 or circuit 20min". The other option would be to search for "Weight lifting (free, nautilus or universal-type), light or moderate effort, light workout, general" in the search field. either way I would manually enter the number of calories in the activity log (this would only need to be done once if you create a custom activity).
Hope this helps
01-27-2014 05:23
Hope this helps
Best Answer01-27-2014 06:36
01-27-2014 06:36
Thanks that helps
