06-02-2014 13:41
06-02-2014 13:41
I have been getting my steps in on the treadmill and have been doing aqua fit at the gym . I finnally am up to a 17 minute mile at an incline of 3. The problem I have now are that a toenail on each foot have blackened. I do not know if I am doing something incorrectly or I need different sneakers. Has this happened to anyone else?
Best Answer06-02-2014 14:37
06-02-2014 14:37
I would go get fitted for New shoes.
Go to a good running shoe store where they will look at your Gait etc. Your feet are worth it
Wendy | CA | Moto G6 Android
06-02-2014 15:14
06-02-2014 15:14
I had that happen after I had hand surgery and had to wear shoes that didn't need to be tied. That was in November, and even though I switched back to my good running/walking shoes, the blood under the nails (just the big toes) just now cleared up.
I agree with WendyB: Go get fitted for some good shoes. I need to replace my shoes about every six months since I put quite a lot of mileage on them. I bought a cheap pair (I liked the color) and went through the soles in a matter of a few weeks. Now I buy good shoes and add good inserts, since I pronate when I walk and my arches collapse. It has made a huge difference!
Best Answer06-04-2014 14:07
06-04-2014 14:07
Yes, I went to have a fitting. Bought a pricey but comfortable pair of running shoes (wider and larger) than old pair. Plus an orthotic insert because have the beginning of plantar fac....(something). I want to get back to my scedule...feel like a slug the past three days. Still have the ugly black nails but that will take some time to heal. Thanks for the recommendation.....glad it wasn't anything more serious.
Best Answer06-12-2014 12:11
06-12-2014 12:11
The blackend toe nails will be due to pressure from shoes that don't have a large enough toe box for your feet.
Best Answer06-13-2014 09:25
06-13-2014 09:25
I would see your doctor. Blackened toes is not a good sign. It may be an infection underneath.
Best Answer06-15-2014 06:26
06-15-2014 06:26
Yes, I tend to agree with @josephz2va - this might relate to sweating more so than fit, due footwear that doesn't breathe properly.
