11-06-2018 15:54
11-06-2018 15:54
What is another name for sit so that I can log it into tracking exercise.
Best Answer11-06-2018 21:05 - edited 11-06-2018 21:05
Want you need to do is set up a custom exercise and call it what you want then you can log it.
It is at the bottom of the exercise tab
Wendy | CA | Moto G6 Android
11-06-2018 22:47
11-06-2018 22:47
What Fitbit model are you using? If supported, you could log in directly on your tracker using the generic WORKOUT activity.
Dominique | Finland
11-11-2018 13:31
11-11-2018 13:31
@catmah.. just curious, are you doing sit ups for an extended period of time that it counts as a workout? or are you tracking data to see your caloric expenditure during?
If Wendy or Dominique offered you a solution, please consider parking their posts as solved so the next person can benefit from your question and their answer...thank you!
Elena | Pennsylvania
11-14-2018 19:30
11-14-2018 19:30
sit ups are called abdominal crunches. they can also be called just crunches.
being a custom exercise tho, you could call them what ever you like.
Best Answer11-15-2018 05:55
11-15-2018 05:55
@bourby Not really the same. Crunches are designed to engage only abdominal muscles while sit ups engage a number of additional muscles groups and are more likely to cause injuries.
Best Answer06-28-2020 10:27
06-28-2020 10:27
How do you create a customized exercise because I don't know how, and can You send screenshots too? Many thanks.
