02-17-2014 09:18
02-17-2014 09:18
Just joined a gym and was given a MyZONE heart rate monitor -- it's interesting using both the fitbit and MyZONE together. MyZONE seems to be all about intensity and heart rate, fitbit seems to be more about steps to me. What's the right blend in utilizing both that works for you? Thanks!
02-17-2014 13:56
02-17-2014 13:56
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
02-17-2014 14:00
02-17-2014 14:00
Sam | USA
08-08-2016 17:35
08-08-2016 17:35
08-08-2016 17:55
08-08-2016 17:55
I don't wear the Charge HR for entertainment, I wear it for the heart rate monitoring and exercise tracking. Is it 100% accurate? No, and I don't think any fitness tracker is. But, I know from day to day what my activity is, and how my heart is reacting to it. That is the purpose of the Charge HR. It is a Fitness Tracker, not a dedicated Heart Rate Monitor, like the MyZone
Is a HRM belt worn around the chest, like the MyZone be more accurate than one worn on the wrist? I would hope so. And, if a HRM function is all you are looking for, you shuold definitely consider a dedicated chest strap type instead of a Fitness Tracker.
08-08-2016 21:43
08-08-2016 21:43
At work, if on the production floor, I can't wear the charge HR on my wrist. I wear it in my bra (it's a soft cup, so not uncomfortable). It still counts my steps pretty well (did a couple of trials) and I still get the benefit of the hr recording. I used to wear a polar monitor with a chest strap. It's not somethimg you would want to wear all day, although I did it once or twice. If I remember though it gave me the same level of high calorie burn. That's the first time I think I realised why I didn't do well on 1500 calorie diets.
If I have batteries for it I may try wearing it for a couple of hours for comparison on the weekend.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
08-09-2016 04:30
08-09-2016 04:30
As a wrist worn HR monitor, it compares reasonably favorably to my garmin chest worn monitor. The image below is an overlay of my Garmin HRM vs. the fitbit worn during the same activity. The lighter image is the garmin. Disregard the gaps in the beginning -- I usually run a short warm up and then stop to stretch -- those gaps are the stretching portion.
This was a 5 mile run where I picked up speed to a sub 7 minute per mile pace at the beginning of each mile marker for 1/4 mile or so. Overall I'm pretty happy with the HRM. The only discrepancy is at the high end. There is about a 6 - 10 bpm difference in the peaks.
Overall, I think it's as good as any other wrist worn HRM. Given all wrist worn HRMs use optics, they have their limitations.
I've also compared exercise calorie counts for running, walking and lifting to my garmin and the METS tables and it matches pretty closely.
So, I think it does a pretty good job (even compared to chest strap monitors) when it comes to aerobic exercise BUT overall the TDEE is off a lot for me -- 750 to 1000 calories too generous. I contribute this to the calorie calculation you get from normal daily activities -- I think it's giving me too many calories for just walking back/forth to the bathroom, cooking dinner, etc... when the HRM is used. When I turn my HRM off it gives me the numbers I expect for exercise and provides a TDEE much closer to what my actual TDEE is.
08-09-2016 18:21
08-09-2016 18:21
@FitBeforeFifty - glad you've already done it. I figured they can't be that far off. I know for some (including you) the numbers aren't close to TDEE, but for me (at my fitness level) they're pretty close. I've decided recently to ignore the super high burn days in respect to calories in, but the HR monitor seems to be pretty close to remembered exertion when I was more into organized exercise.
08-10-2016 23:45
08-10-2016 23:45
My gym Snap fitness gave me the myzone tracker. I wear it on my shoes. For step accuracy i actually have a large charge hr and i put it on my ankle so my steps are dead on. i like being able to compare them both. i use the myzone because my gym does contests based off the information from it
07-07-2017 07:42
07-07-2017 07:42
I have a myzone from my gym and I didn't know it would track your heart rate from your shoes! I have a chest strap. I also wear a Fitbit and find them to be wildly different in calculating calories.
07-07-2017 09:10
07-07-2017 09:10
I've seen similar findings. My exercise activity seems to be spot on, but my overall seems rather high..
