It is convenient to use the scan or search options for different foods but the "custom " feature is cumbersome to add each item individually. Other competitor apps allow you to scan multiple items in the "custom" area so that you can personalize recipes or foods with multiple components. Take a protein shake, for example; add a scoop of protein, milk, fruit, etc. With Fitbit, you would need to manually add all the components and nutritional information. With other apps, you could scan each item and just modify the portion amount and be able to store and access the custom recipe each time you need it.
Is this a feature that is coming or available now and I just am not using the program correctly?
