05-04-2015 12:50
05-04-2015 12:50
Best Answer05-04-2015 17:01
05-04-2015 17:01
In myfitnesspal you can connect the fitbit app to myfitnesspal.
In Myfitnesspal go to apps.
Fitbit should be one of the available apps and should be one of the first ones under featured apps.
Click get app and follow the onscreen instructions.
You will have to enter your username and password I believe for fibit for the two apps to connect.
Once connected, just enter all of your information into myfitness pal and it will automatically go over to fitbit since you linked the two together.
This way you only have to enter your information once and it goes to both places.
Hope this helps!
05-04-2015 18:44
05-04-2015 18:44
