10-10-2017 11:12
10-10-2017 11:12
I am sure I saw an item on how much water should be consumed but the goal panel has gone. Where can I find this info now?
Best Answer10-10-2017 21:56
10-10-2017 21:56
Try this sight although I think the amount of water we need is very individual.
Best Answer10-11-2017 00:48
10-11-2017 00:48
Thanks for this but maybe someone from FitBit can direct me to where the original info on FitBit can be found.
Best Answer10-13-2017 00:25
10-13-2017 00:25
Hi, thanks for sharing the link.
Best Answer10-13-2017 02:09
10-13-2017 02:09
Here is what I see in my app:
Is this what you mean?
Dominique | Finland
Best Answer10-13-2017 02:19
10-13-2017 02:19
Hi and thanks for your reply. Yes that it partly what I mean. Just below the top section there was a panel to get advice on goal setting. That panel has now gone because no doubt I viewed it before I knew what I was doing and the App decided I didn’t need it anymore.
Best Answer10-13-2017 02:59
10-13-2017 02:59
I guess it’s Fitbit avoiding to be too prescriptive. Similar subtle changes have occured along the years. For instance, there used to be a table with various body fat ranges (normal, fitness, athlete etc.) in the Weight tile: now it’s only "Based in your gender, the normal range for body fat is 14-24%".
Dominique | Finland
