05-07-2023 10:09
05-07-2023 10:09
I cook mainly from scratch. I would like to save my recipes because i often use less salt and fat than commercial products. How do I accomplish this on the site?
05-10-2023 20:47
05-10-2023 20:47
Just wondering about any help others can give me about creating my own recipes on this site. People have been looking, which is fine. I had hoped there was a way to put the ingredients for some of my dishes so that I would not have to type in every ingredient every time. Can anyone help?
Best Answer06-26-2023 17:28
06-26-2023 17:28
I wish I could be of some help, but I'm pretty new at using the food log on Fitbit. I would like to be able to do it as well, so I'm hoping that someone will know an answer.
Best Answer07-05-2023 03:59
07-05-2023 03:59
I'd like to help, but have the same issue. I switched to fitbit after just using a simple dieting app, unless I'm just not doing it right, I'm surprised how limited the food intake part of the app is; if I want to eat processed ready made meals and some cans of I can enter no problem, but to create a home made meal, with say some pulses, olive oil, yoghurt and save that as a regular recipe seems to be beyond the apps capability, which is surprising and very frustrating. Hope someone can help
Best Answer07-06-2023 08:49
07-06-2023 08:49
I access the Fitbit app on my computer. Where you log your food is the option to create a meal. The downside is you need to figure it out on paper how much one serving is and enter that as your meal. If you enter ingredients for a pot of soup, you can't use 1 cup as a serving you get the whole thing.
Best Answer07-08-2023 08:56
07-08-2023 08:56
I'm going to try to log it in as a meal instead of every ingredient. If you add up all your calories, fat, etc. and log it as a meal under a name or number (chick/quinoa or meal #1) I think it should be easier if you're eating the same basic meals weekly.
Best Answer07-17-2023 07:37
07-17-2023 07:37
I have the same issue and solved the problem by building a recipe on a nutrition calculator, then manually entered the nutrition data in Fitbit under create a new food. It's tedious but the only way I could find. Fitbit, please add a nutrition calculator.
