01-12-2020 04:36
01-12-2020 04:36
I by mistake recorded too much in how much water I drink; is there any way to correct it?
Thanks
Best Answer01-13-2020 10:31 - edited 01-13-2020 10:55
Hi @Faye04
Are you using the Fitbit phone app? If so, tap on the water on the dashboard, tap on the day of the error, tap on the item in the log history you want to change - this will allow you to adjust the water log. You can also delete that specific logged water by tapping in the trash can in the upper right-hand corner of the screen.
If you are using the computer dashboard, click on the water tile, then click on see more in the lower right hand corner, scroll down to water, go to the logged water entries, there you can delete with the "x" and then re-log the correct amount.
Please let me know if this helps 😊
Hi @Faye04
01-13-2020 14:49
01-13-2020 14:49
THis did help thank you so much
