how can i delete an entry in my food log if i entered it incorrectly
how can i delete an entry  in the food log if i logged it incorrectly?
4 REPLIES 4
Well, you didn't state if using app or website, since of course they are different.
So website - hover over the food item - an X appears and says Delete. Click it.
Help the next searcher of answers, mark a reply as Solved if it was, or a thumbs up if it was a good idea too.
@jenniferlynn57 this link will help you with all devices. Simply click on your device and click the link that best suits your needs. http://help.fitbit.com/  Depends on where you want to delete your entry; on computer, cell or other app. Let me know if you have any problems. Easy way online is look for the x on the left of the item as you hover over it then click. My Windows phone with MyFitnessPal I hold over the food and it provides the option to delete; same for activities. Hope this helped you.
Dawn | USA Flex Charge HR Charge Surge Blaze Versa 2 Android
Is there a way to adjust the amount of a serving ?
for example I entered a food which listed the amount as .5 oz, however, I actually had .75 oz
how to I reflect that in my daily food log ?
Thanks,
Bruce
Hi Bruce, on my app all I have is some fractions and not decimal points. Therefore, if it was .75 then I would select 3/4 oz. not sure if that helps you.
