07-09-2024 12:53
07-09-2024 12:53
Hello - switched from Charge 5 to Inspire 3.
WAY limited in metrics - Heart Rate, Steps, etc - on the same face.
Anyone know the best way to get more features on there?
Best Answer07-10-2024 04:02
07-10-2024 04:02
@ncspartan I'm sorry, but Fitbit decides which clock faces are available for each tracker model. The best way to give feedback to Fitbit is in the Product Feedback forum. Please vote for and leave a comment on this request.
Laurie | Maryland
Best Answer07-10-2024 04:04
07-10-2024 04:04
Hi, @ncspartan, welcome, the amount of information available on the device screen is limited by the real estate available. May I suggest you try all the clock faces available in the Fitbit app for the Inspire 3, do take a close look at the settings for each as they can be personalised on some. If you still feel an improved design should be available you can post your suggestions at Submit feedback - Google Communities Help
I hope this helps.
Cheers
Gr4ndp4 | UK
