03-27-2024 11:40
03-27-2024 11:40
When you're tracking exercise you should be able to select which metric stays at the top. As it is now you can either see distance if it is tracking via gps or calories if it is not.
Best Answer03-29-2024 03:16
03-29-2024 03:16
Hi, @Doubleday90 , that depends on what exercise you are doing. For walking and running, for example, the metric at the top is not calories - it is distance.
The Inspire 3 is one of the more basic Fitbit trackers and Fitbit has chosen what the developers feel is the most appropriate metric for the bottom and top. However, the main, centre metric is customisable. If you tap your Fitbit during exercise you can scroll through the other options and choose your preferred metric.
If you would like to be able to customise all 3 metrics you would need to upgrade to one of the smartwatches, which do have the option to select and customise all 3 metrics.
