About 4 months ago I finally managed to stop the Premuim Service I didn't need anymore. A few months later, I realised that my Fit Inspire 3 had stopped syncing to my when I stopped Premium. I have been trying to get it to sync since. I have uninstalled and deleted the fitbit app, reinstalled it but I still get "something went wrong" with 2 options, try again or cancel. I've tried again, and again, there is no point, it is not working. Exiting doesn't help, as I haven't managed to add my Fitbit. Nothing helps, I don't know what to try next.
Best AnswerHi, @LGams2020, welcome to the community. If I understand you correctly, you are having difficulty pairing your Inspire 3 with the Fitbit app on your cellphone. The last time you were successful was a bit less than 4 months ago. First, check that your cellphone is still compatible with the Fitbit app, as the minimum OS version is occasionally updated. Fitbit Setup Requirements - Help explains potential issues. If you have updated the Fitbit app on your phone (you do not mention the make or model), the latest Fitbit app version may no longer work on an older phone. If you have a phone with an acceptable OS, the best way to move forward is to create a clean slate on your phone and reinstall the current Fitbit app. I recommend following this procedure: Go to your phone settings, apps>Fitbit>force stop>clear storage>uninstall. Go to your phone, connected devices & "Forget" your Inspire 3. RESTART YOUR PHONE. now reload the Fitbit app from the Play Store & log on using your Google account. If you can, restart your Inspire 3. Check that your Inspire is charged. Try to pair again.
If you are still not able to make progress, consider your "Bluetooth" environment. Turn off any other Bluetooth devices nearby or at least move them well away from where you are working. Try to pair again.
You do not mention how long you've had your Inspire 3, but you may still have the benefit of Fitbit's warranty depending on when, where & from whom you bought it. You can claim by contacting Fitbit via the Fitbit app (Help).
I hope this helps.
Cheers
Gr4ndp4 | UK
I hope this helps.
Cheers
Gr4ndp4 | UK
