Sleep spo2 95/96% Breathing rate 17/18 bpm. If I google, these are not optimal numbers. Should I be concerned?
Best AnswerHi, @shaw38 , welcome to the community, you may find this article of interest Track your health metrics in the Fitbit app - Fitbit Help Center . If you have particular concerns you should consult your health professional.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerHi @shaw38,
I wouldn't be too concerned about that single-point measurement of breathing rate and oxygen saturation if I was you.
Google AI suggests that a breating rate of 12 - 20 bpm is normal for adults and your oxygen saturation is fairly respectable as well. I would recommend wearing the device for at least a month and then take a look at the trends for breathing rate and oxygen saturation at that point in time first, because those metrics do change over time.
