Fitbit Inspire 3
Does anyone recommend this? I've never had a fitbit before wondering if this is a good one or if there are any other recommendations?
1 REPLY 1
@taulaba7 , A warm welcome to the Community! Thank you for your message.
It all depends on your needs.
If you are looking for something slim, compact and only to track your main stats, the Inspire 3 could be a choice.
If you need something with integrated GPS and something to track/ smeasure an ECG, then the Charge 5 or Charge 6 could be the option.
Or if you want to install other apps a Smartwatch ( Sense serie, Versa Serie, Pixel Watch Family) could be the way to go.
Here is a link, where you can compare the different models, and help you with your choice. Find your perfect fit.
