Hi, @Sgustavson , you need to request this using the web based dashboard rather than the app. You can access it via these Community Forums whenever you are logged in. At the top right hand side of every page in the Community you will see a link to “Dashboard”. Click on that and on the dashboard screen click on the gear icon top right to go to settings. There you will find a link from the drop down menu left side to “Data Export”. You will see a link to request your data. You have a lot of data so archiving it for you and then downloading it will definitely take some time!
Good luck! I hope this helps. Welcome to the Community Forums!
