How strong is the alarm vibration on the Inspire 3?
My Timex with vibration alarm is about to die and I'm looking for a new vibration alarm watch.  I've read on this forum and other websites that some Fitbit models have strong vibration alarms and others are very weak.  For example, I've read the Sense and flex were weak but the recalled Ionic was strong.
I don't need other fitness features -  only a reasonable vibration from the watch - and would like to spend the least amount on a Fitbit that gets me there.  Should I get an Inspire 3, or get one of the other models?
1 REPLY 1
Hi, @nellborg , the Inspire 3 has an option to have “normal” vibrations or to set them to “strong”.   You will find this on the settings menu on the Inspire 3 tracker. I find normal perfectly adequate for me, so I don’t miss any alerts.  Of course no one can know for you for certain, but I would think the “strong” setting would be fine in day to day wear.
I find the Inspire 3 easy to set up and navigate and I would definitely recommend it.  It is easy to ignore the features you do not need.
I hope this helps.  Welcome to the forums!
