Hi all,
I have try somme clock faces and i want to return to the original one but i don't know how.
I have try a reset on the watch but when it restart it let the last clock face.
Thanks.
Best AnswerAh, I see. I did Google search and found the original Inspire 3 clock face is called Highlight, if that helps you at all. 🙂
I'm not sure if it's different on an Android than an iPhone (I have iPhone), but if you go into your app, choose 'gallery' and on the top choose "clocks" the different clock face styles appear. Choose the one you want and then choose 'install' and see if that works for you. Good luck!
Best AnswerThanks for your answer, i can install some clocks without any problem, but i want to go back to the orignal one and i don't found it in the gallery and don't know how to desinstall the one i have.
