08-11-2024 05:45
08-11-2024 05:45
Just bought an inspire 3.
I just went for a walk and as soon as I hit 60 minutes of walking, I kept getting a CONSTANT stream of vibrating notifications letting me know that I have increased my AZM by 1 minute. "61, 62, 63, ..."
I can't even tell the time because the notifications are constant. I've restarted my device, I've turned off AZM notifications on the device, set AZM minute goal to 2880 (max) in the app, but still these constant notifications.
Has anyone encountered this before/found a solution?
Best Answer08-12-2024 02:55
08-12-2024 02:55
Hi, @khdanbo8 , turning off AZM notifications on the Inspire 3 should work. If it doesn’t I would recommend turning AZM notifications to ON on the device, sync your Fitbit, then turn OFF again and sync again. Hopefully that should reset it.
However, if that doesn’t work an alternative would be to change your settings in the app. From the opening, Today, screen of the app click on the small icon top left (watch and smart phone). On the next screen choose the picture of your Inspire 3 and then “Notifications”. Next choose “App notifications” and scroll down to find Fitbit and uncheck the box for notifications from Fitbit.
Good luck! Let us know if this works for you. Welcome to the Community Forums.
