04-25-2023
11:29
14:22
ManuFitbit
04-25-2023
11:29
14:22
ManuFitbit
My Fitbit has been working fine up until this point. Since I got up this morning, I can't seem to get it to scroll up or down more than one screen, and even that requires multiple attempts at swiping. Is there a setting I can change for this? How might it have gotten into this state?
Moderator edit: clarified subject.
Best Answer04-26-2023 03:18
04-26-2023 03:18
Hi, @FuzzyBoots , I would recommend giving your Fitbit a restart. Instructions are here . A restart can fix many issues causing your Fitbit not to perform as expected. Sometimes you need to repeat the restart procedure, as a single restart does not always help.
Best Answer04-29-2023 05:25
04-29-2023 05:25
The issue went away, before I could restart it, later in the day. I still have no idea why it was acting that way, but so far it is behaving.
