02-21-2026
10:41
12:35
HorareyFitbit
02-21-2026
10:41
12:35
HorareyFitbit
I have the inspire 3 and want to see my HR graph after a work out. On the app it says 'no data'. Is it possible to see the HR in a graph? Thanks
Hi @KateDa, welcome to the Community!
As a first recommended step let me suggest you to check if there is any update in your device pending, you can check for reference the article ¨How do I use the Fitbit app?¨ in the section ¨How do I update the Fitbit app?¨
Best AnswerThanks for your reply. Yes I have already checked for updates and i am up to date with that. After exercise it will show time spent in different zones but will not give highest/lowest HR. When I click on HR it says "No Data wear your device to get HR data'....It gives my cardio fitness score - but doesn't tell me HR .....
Hi @KateDa! Thank you so much for your reply.
Our team is aware of this inconvenience and is working to find a solution as soon as possible. I appreciate your patience and hope that these problems can be resolved soon.
In the meantime, we suggest you keep your mobile and your application updated, as this is how you will receive the solution to this problem.
