02-28-2024
13:15
14:05
JuanFitbit
02-28-2024
13:15
14:05
JuanFitbit
Since February 21, 2024, my Inspire 3 is only providing me with simplified sleep info. No score or heart rate or breathing info is being provided anymore.
Best Answer02-28-2024 14:05
02-28-2024 14:05
@Inspectorb3 , A warm welcome to the Community! Thank you for your message and information.
The following conditions can prevent sleep phase recording:
- You record your sleep using the Fitbit app instead of the tracker's automatic sleep detection.
- The tracker's battery is almost empty when you go to bed (below 25%). This prevents the pulse from being recorded regularly.
- You use the metal bracelet while sleeping
- You sleep less than 3 hours.
- The bracelet is too loose or too tight on the wrist. You should be able to put your index finger between the bracelet and your arm without much resistance so that your pulse is recorded regularly and sleep phases can be recognized.
02-28-2024 14:08
02-28-2024 14:08
Thank you, I’ll try loosening the band.
03-01-2024 05:44
03-01-2024 05:44
I have had the same issue since Feb 18. I’ve updated the software, checked my settings, restarted, and adjusted my band multiple times. What else you got?
03-01-2024 12:32
03-01-2024 12:32
Hi Mthel, I too have tried everything you listed without any success. If you do get it figured out, please let me know here. And I will do the same; its so frustrating.
03-03-2024 07:15
03-03-2024 07:15
@Mthel @Inspectorb3 , Thank you for your reply! Please try wearing the Inspire ,so that the heart rate sensors are touching the back side of your wrist. Here it's easier for the heart rate to be recognized.
Please make sure that the Inspire 3 is on wrist mode and not on clip mode.
03-03-2024 09:04
03-03-2024 09:04
The band is def set on wrist mode. Not sure what else to try but nothing mentioned has given me back my sleep number or breathing tracking as it had been doing until February 21st.
03-03-2024 17:37
03-03-2024 17:37
Same. Sleep score stopped a week ago. Tried all these fixes and restarting fitbit, plus deleting and reinstalling app. The sleep score is why I pay for premium.
03-04-2024 01:59
03-04-2024 01:59
Got a sleep score this morning. Don't really understand why it works now as I did nothing yesterday to fix it. Just hope it continues to work.
03-13-2024 05:03
03-13-2024 05:03
Nope, that didn’t work either. I’ve had one night register the full sleep data in the last month, and I did nothing different to make that happen.
Best Answer03-13-2024 06:42
03-13-2024 06:42
I still have had no luck, wishing others would chime in with ideas. I can't believe we are the only ones not getting scores or breathing results while I sleep, which is why I bought the Inspire in the first place.
Best Answer03-13-2024 07:04
03-13-2024 07:04
I've noticed a recent change in sleep recording as well. One night it didn't record any sleep phases at all. The sleep times and wake times aren't accurate anymore. I've relied on this for years, so this seems very strange.
Best Answer03-13-2024 12:37
03-13-2024 12:37
Hi everyone! Thank you for your messages and information.
We released a new app version (4.12) . Please make sure to update it. Keep an eye for a few nights and let me know if you are still receiving the simplified sleep record afterwards.
Best Answer03-14-2024 06:49
03-14-2024 06:49
Hi Juan,
I do know that I did recently update my fitbit due to a notification to do such and that's when it seemed like my sleep score stopped recording. Can you please advise us on how to verify our current version? and how to update if needed?
Best Answer03-14-2024 10:12
03-14-2024 10:12
@Inspectorb3 . Thank you for your message.
In the Fitbit app, tap on the settings icon (gear icon upper right corner) > Help & Support.
You'll see below the title the Fitbit logo and the app version used.
Best Answer03-15-2024 12:58
03-15-2024 12:58
Thank you Juan. My version says 20001.194.91. I am confused as its nothing close to saying 4.12.
Best Answer03-17-2024 10:08
03-17-2024 10:08
@Inspectorb3 , Thank you , it seem that you are looking at the Firmware update from your Inspire 3 .
Could you please attach a screenshot of what you see, following this path?
Fitbit App > Gear icon (upper right corner) > Help & Support.
So that I can see what you see on your screen.
