06-10-2025
05:32
05:50
MarioSFitbit
06-10-2025
05:32
05:50
MarioSFitbit
I am still not getting a regular sleep score, it has been going in for months. It works for a few days and then stops again. Os this ever going to get resolved?
Moderator edit - updated subject for clarity
Best Answer06-10-2025 16:47
06-10-2025 16:47
Hi, welcome back to the community @Cdaines.
Thank you for sharing the details with me regarding the difficulty that you are experiencing with your Inspire 3.
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages. Keep in mind that you must see sleep stages in order to see a sleep score.
In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
As you know, the Inspire 3 may need some days to collect some information (particularly regarding heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here. In case the issue is related to the Fitbit app, please try the following as well:
Best Answer06-10-2025 22:57
06-10-2025 22:57
I’ve done all that hundreds of times & it doesn’t make a difference. I’ve had a fitbit for years & never had this many issues
